It is currently Sun Mar 29, 2026 12:37 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3  Next
 Post subject: Clutch trouble
PostPosted: Sat May 03, 2008 1:53 pm
(my '80 2WD)... I pulled the eng. and took the clutch off. It looks worn and has been hot, but it's not into the rivots at all.
When it was up and running, it seemed to slip a little.
I was trying to drag something backwards once, and I was able to get the clutch pedal all the way out and not stall the eng. (this I'm sure explains the signs of heat).
Has anyone else done this? I thought a good clutch would kill the eng. every time.
I've done this with my 4X4 also, while in 4X4 low. I got the clutch pedal all the way out, about half or so, throttle tire in a ditch, and eng. running, tires stopped. Clutch slipping. :?
Are the clutches just a weak link on these drive trains?
 Post subject: Re: Clutch trouble
PostPosted: Sun May 04, 2008 6:48 pm
sounds to me u need heavier clutch pressure plate and i would say u will need a new cluth plate try a heavy duty organic clutch plate it may help
PostPosted: Sun May 04, 2008 9:09 pm
First check for proper free play. Should be able to push the pedal down about an inch with your fingers before any resistance is felt. I believe they tend to be a little on the weak side but should still kill the engine. You may want to put in the 80 4x4 clutch as it was improved on those models. It was 1/2 in larger diameter with probably a bit stronger pressure plate assy. The fact that they improved it means to me they had complaints, or some problems.
PostPosted: Mon May 05, 2008 7:17 pm
I didn't think of that. Oh well. I got a new clutch from my mom n pop auto supply for $65. And a refurbished fly wheel for $38. So when I get time I'll put it back together. It even came with both bearings. 8)
The new clutch looks a little different than the old one. It looks better. So I think the old one was a cheapo someone put in trying to save $.
PostPosted: Wed Jun 18, 2008 7:37 am
Hey Rondog, it's a clutch problem for me now. I ran up a couple hills with a yard of L & G Premium and the clutch couldn't handle it. The cheapest I've found so far is $89 for the clutch set at PartsAmerica. I'm gonna have to do it within the week. I know I don't know every thing, and if you'd care to share your tips I would be grateful. :signoops
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Jun 18, 2008 1:05 pm
PITA Old Fart
Ron...from what I've noticed, the original stock clutch setup was a bit weak. Plus, if the guy that had the truck before you did a half-baked clutch job - then that would explain it easily. Because when you got a bad slipping clutch that doesn't engage with a big load in your truck on a hill - that's from friction heat overcoming tensile strength.
Spend a few bucks and get the heaviest/toughest clutch disk, throwout bearing, flywheel, and especially the pressure plate (replace them all with all brand new and not rebuilt parts) you can. I've burned a few clutches and had a couple blow out in the middle of nowhere with a big load in the truck- so I've learned the hard way. And if you put a new clutch disk in with a overheated/scorched flywheel and pressure plate - you'll be right back where you started again in no time.
Also I'd compare brands - because I've seen some pretty lousy made clutch disks and pressure plates that look like they were just thrown together at the last minute on a payday friday, or that were put together sloppily on a monday by someone with a bad hangover from a 3-day weekend of partying way too much...lol
I went with the heaviest 4X4 flywheel, pressure late, throwout bearing, and clutch disk I could find. It cost a bit - but a friend of mine with a Pup running a hybrid 2.3/2.6 has put 3 cheapo clutches in his - and it hasn't been on the road half as long as my truck has.
(And he kinda baby's his truck - and I sure don't...lol)
...Just my $.02 worth.
PostPosted: Wed Jun 18, 2008 1:24 pm
sleeps at LUVTruck.com
i didnt think the clutch was a weak link in the drivetrain. i mean my truck (79' 4x4) still has the original clutch. :?
PostPosted: Wed Jun 18, 2008 2:21 pm
I allways deep step my flywheels. Basically have your flywheel machined and where the pressure plate bolts up have them surface that area another .015 or so.
PostPosted: Wed Jun 18, 2008 4:35 pm
I'm going to replace it all like Tazman said. I was wondering if I could stay with the same flywheel, but I know myself it's gotta be gone too. Basically the whole clutch set is overheated by overloading to an extreme. I asked the gravel people how much it weighed, the dirt I hauled, and they said it was 2200 lbs., and the Luv is supposed to be a half-ton truck; doesn't that mean 1,000 lbs.? The fact that I went up a couple hills didn't make things better. I did feel some chattering, but when I slowed down I thought I would be okay. Now it hasn't any takeoff power, and two different guys told me it was an adjustment. I tried that, but even though I took out more of the play in the pedal it still had the same lack of torque during acceleration. Gotta go order parts. Thanks for all the advice.
Luvrv8, it cost less to buy a new flywheel than it is to have it machined. Luvmytruck, congratulations on having an original clutch; you save money and you're a good driver. I should be less abusive to my ride. Egg, I did adjust the free play but it made no improvement. I wish it was just an adjustment. Rondog, are you finished with yours already? Did you take any photos?
Image Image
PostPosted: Wed Jun 18, 2008 4:51 pm
I dont know what you guys are paying for flywheels but I get mine machined for 18 bucks here, 22 for deep steping.
PostPosted: Wed Jun 18, 2008 4:59 pm
If I can get that price I might try that, but I think they want about $40 here, and the flywheel was $35 last time I got one.
Edited--I just talked to the shop, and Kathy said they charge $35 for the flywheel turning.
Image Image
PostPosted: Wed Jun 18, 2008 8:55 pm
The new clutch is in and done in my 80 2WD. It drives great. I haven't tried to pull anything, just been doing normal driving.
The last straw for the old clutch was, I was trying to pull my trailer backwards up my driveway. It weighs about 10,000lbs. I chained the back of the trailer to the front of the pick up and was just trying to tug it about 10 feet. Well, we went to plan B after that. :roll:
The 4X4 clutch works just fine around town. I was trying to pull my Ford out of a ditch when I was able to slip it.Once it was slipping under load and the Ford didn't move, we stopped be for we did any damage. I just expected to not -be able to let the clutch all the way out, 1/2 throttle and not move. 8O My son pulled my Ford out with his Ford.
Fulla, I didn't take any pics. I just pulled the eng. out. I felt it was easier than laying on my back and fighting the trans out and back in. Plus, it is easier to swap out the pilot bearing and flywheel this way.
PostPosted: Thu Jun 19, 2008 3:24 am
Thats the thing, pulling backwards is a lot harder work.
Im not to sure about the stepping the flywheel thing. Best to get an up rated clutch.
Bob.
PostPosted: Thu Jun 19, 2008 11:25 am
When I was younger and we were using my stock '76 to haul heavy loads around my grandpas farm, we had the clutch do the same thing to us.
It's basically the equivalent of brake fade. Haven't you guys ever gotten your brakes hot enough that they don't work any more?
PostPosted: Thu Jun 19, 2008 1:53 pm
And just like brake fade it only happens from overuse and thats because you under clutched for the job your asking of it. Same goes with a vehicle with bad brakes.
A clutch should be like a switch. On or Off.
I keep telling the Mrs that. Shes like its only a clutch i will buy one. I told here she would be fitting it as well and she didnt like that.
If you have to to ride the clutch i say your using the wrong vehicle for the job.
Bob.
PostPosted: Thu Jun 19, 2008 2:56 pm
PITA Old Fart
Agreed. That's why they are called "light duty mini trucks"...lol
Quote:
I ran up a couple hills with a yard of L & G Premium and the clutch couldn't handle it. I asked the gravel people how much it weighed, the dirt I hauled, and they said it was 2200 lbs., and the Luv is supposed to be a half-ton truck; doesn't that mean 1,000 lbs.?
BRILLIANT!!Image
PostPosted: Thu Jun 19, 2008 9:20 pm
I'll just have to go lighter from now on. My Luv is still going, although the power is gone, I still drove it some. I might see about doing the clutch job over the weekend. I better get it done before I get stuck out somewhere, ha ha.
Image Image
PostPosted: Thu Jun 19, 2008 9:59 pm
Bob.
Yep, I also agree. Thats why I stopped once I realized it ain't gonna happen like this. We need more vehicle. My *0 needed a clutch anyway. But the 4X4 I quit before I destroyed anything. It still goes great.
My daughter now has her license, school is out, and I haven't seen the truck since. :D
PostPosted: Thu Jun 19, 2008 10:12 pm
Am I understanding this correct, you say power is down and torque is down. Is that what is going on or is your clutch slipping?
PostPosted: Fri Jun 20, 2008 12:02 am
In low range???
Going backwards???
Manual locking hubs???
Should have been about to drag a fair weight.
My mate is up to clutch 3 on his 94 pup. It regularly tows things it should not. Trucks and things like that, like full size prime movers and stuff.
Bob.
Users browsing this forum: Google [Bot] and 30 guests
