It is currently Mon Jun 29, 2026 4:06 pm
 Post subject: heater hose help please
PostPosted: Sun Feb 24, 2008 10:25 pm
i put a new raidator in my 76 luv the other day at that time i also instaled a new heater bypass hose it comes from the front of the head and goes under the intake close to the startor all of that went as well as can be expeted i could not fidger out why i was not bulding up any pressuer in the system i checked it today were the heater bypasss hose goes on it "t" off and on the other side is were one of the heater hose goes on i found a hole in my heater hose does anyone know were i can find one to replace mine
I will no longer do that thing with my tongue
PostPosted: Tue Feb 26, 2008 3:31 pm
MY FRIEND THAT I BOUGHT MINE FROM FOUND ONE THROUGH HIS WORK! I CAN GET HIS INFO IF YOU LIKE! HE IS ALSO THE PREVIOUS OWNER OF MY LUV!
Luv my Luv? I do!
PostPosted: Tue Feb 26, 2008 6:29 pm
please get the info and post it up for everyone
PostPosted: Tue Feb 26, 2008 8:33 pm
yes please its killing me to not be able to drive my luv truck around
PostPosted: Tue Feb 26, 2008 9:10 pm
usually ill take a hose from the luv to the parts store and come as close as passable to the luvs with what they have hanging in the back... sometimes you have to add a union and make two hose work where the luv only had one... but they work fine
PostPosted: Wed Feb 27, 2008 1:58 pm
yeah all my hoses were trashed when i got this truck and it blew, so during the rebuild my dad and i just went to a parts store that carries hoses and had them match as close as possible. some of the hoses we had to cut, and bend as much as we could because they weren't made specifically for my engine, but they work perfect. just kind of a tight fit!
PostPosted: Thu Feb 28, 2008 3:17 pm
yeah. mine are a collection of ends from old heater cores connected with hose.... good way to get the solid bends and the junkyard was basically giving me what i needed
PostPosted: Tue Mar 18, 2008 11:32 am
I had to to replace that same hose just this week on my 80 2x4. I took the old hose with me to the local AutoZone and to my amazement, they had that exact same hose hose molded to fit perfect. They didn`t have it in stock but they got it for me in 3 days. $22.00 !
Ike
Only God can make a tree.......
and only Chevrolet can make a LUV !
PostPosted: Tue Mar 18, 2008 1:56 pm
you got a part number for that thing
PostPosted: Tue Mar 18, 2008 3:04 pm
Yes, the AutoZone part # is 63025. The GM # for series 9,10 and 11 is :94205556.
Ike
PostPosted: Sat Mar 29, 2008 11:47 am
I had the local NAPA match up some hoses to replace the old heater hoses. They are almost a perfect fit and when I find the receipt, I will post all the part numbers for the hoses!
PostPosted: Mon Apr 28, 2008 11:08 am
I ran into this problem as well But somehow a nearby store called SP Automotive
had one in stock so i was able to replaced this hose new ....Kewl :D
...............Here's the info for those who need one......................
Hose from Tee under intake to front of block
Dayco P/N's 70893 also on sticker 038244 136452
Users browsing this forum: No registered users and 60 guests
