It is currently Mon Jun 29, 2026 7:25 pm
 Post subject: Im stumped!
PostPosted: Thu Apr 17, 2008 10:08 pm
I was recently gifted my late granfathers old 75 chevy luv mikado wich i learned to drive on......and ive put many of many hours getting it to run...battery,wires.plugs,gastank,put electfuel pump, coil, carb(weber).altanater...fuses...you name it..coil.distribitor..whatever..and guess what it runs great!..for like two to 5 minutes and then it just dies...and stalls ...?? help me please.....!
75 luv mikado
 Post subject: Re: Im stumped!
PostPosted: Fri Apr 18, 2008 4:02 am
Australian LUV Guru
Does it start right up again after stalling or do you have to crank the starter for a while?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Apr 18, 2008 3:24 pm
yes it does...it fires right up perfectly.......
75 luv mikado
PostPosted: Sat Apr 19, 2008 6:56 am
Australian LUV Guru
Before hitting the starter next time it stalls, look down the carb and have someone pump the gas pedal. You should be getting gas squirting, if not its a fuel pump or float level problem. :idea:
PostPosted: Mon Apr 21, 2008 3:27 pm
hey thanks a million!!!..checked fuel pump relay switch and it was faulty .....put another check in the wins column..ozluvtrucker...
75 luv mikado
PostPosted: Wed Apr 30, 2008 12:56 am
Hi Jluvgolf,
Some more info on testing relays at this thread... if you didnt see it.
viewtopic.php?f=5&t=16677
MT
Users browsing this forum: Bing [Bot] and 61 guests
