It is currently Mon Jun 08, 2026 10:28 am
 Post subject: i have random spark
PostPosted: Wed Apr 02, 2008 8:57 pm
i bought the truck not running, ive put lots of time in new intakevalves and cam timing. now it fires and runs for like 2 seconds. and the spark is random in the distrib, points have been gapped and cleaned. new coil. any ideas?
 Post subject: Re: i have random spark
PostPosted: Wed Apr 02, 2008 11:48 pm
New points, cap, rotor, wires and plug? If not, change all of these. How is the ballast resister?
PostPosted: Thu Apr 03, 2008 12:02 am
:D:D:D dont even go there lol. i found ONE resistor for 45bucks. ill just go buy a coil that dose not need one. i already have the alt that is internaly regulated
PostPosted: Thu Apr 03, 2008 5:42 pm
the solution: condincer was bad i swapped out a new one and fired right up
now my problem is my cam sprocket keeps coming loose yes i remembered to torque it the pin slids around and eventually comes out after about 30seconds of running
PostPosted: Thu Apr 03, 2008 6:18 pm
Do you have all the proper parts for the cam sprocket? There should be a large bolt and a large,thick washer to hold all this tight. Clean any oil residue off the cam face, the sprocket face, and the washer face that contacts the cam sprocket. The pin is only used to time the cam to the sprocket, the cam is driven by the friction of the tightened bolt and washer. Torque is 58 ft lbs as you probably know.-----Hope this helps.
PostPosted: Thu Apr 03, 2008 6:40 pm
DUDE the washer!!!!!!!!!! OMG
there never was on on when i got the truck. haha thanks
Users browsing this forum: Google [Bot] and 25 guests
