It is currently Sun Jun 28, 2026 11:58 am
 Post subject: 87 pup ?
PostPosted: Fri Jan 30, 2009 12:08 am
ok i been tryin to do little research but not really having luck i have a 87 isuzu pup bagged layed out on chrome hummer H3 wheels sorry just kinda do little intro since i new but anyways i my motor (1.9) cracked this winter and i been trying to find out what all motors swap onto the 4spd trannys i know the 1.8 does but i really want to know if the 2.3 would bolt on it or if i did the 2.3 and could do the 5spd tranny and it all bolt up
plz in help bad let me know
thanks
 Post subject: Re: 87 pup ?
PostPosted: Fri Jan 30, 2009 12:24 am
1.8-2.6 have the same pattern you can go with the stock 4 speed or upgrade to the 5 speed. If you go with the 5 speed you will have to have a custom driveshaft made.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jan 30, 2009 12:30 am
k so i can a 2.3 will bolt right in then
PostPosted: Fri Jan 30, 2009 3:41 pm
Why? If it's a later-model 5-speed with different spines on the output shaft, why not just use the 5-speed's whole driveshaft?
Users browsing this forum: No registered users and 84 guests
