It is currently Tue Jun 09, 2026 12:19 pm
PostPosted: Mon Mar 31, 2008 11:15 am
Well, it's getting closer, but I still have some minor annoyances with my '78
So far, I've fixed an exhaust problem (minor one- the muffler fell off), set the timing at idle to 6 degrees BTDC, set and emery-boarded the points, rebuilt the carb, put on a new (to me) fuel pump and a new fuel filter upstream of the pump, put on a high-flow aircleaner cause it was running a bit rich and changed the plugs.
Here's what I got left, running problem wise:
-- Backfires on decel: just little pops and burbles when I am engine-braking, but it occasionally really goes off when I change gears.
-- Sluggish: It's okay around town, but on the highway it just feels wrong at speed- like it deploys a parachute at 60. It'll cruise at 65, but it sure feels like it's straining. Maybe that's normal, I dunno.
-- Stumbles off idle. When I hit the gas from idle, it tends to want to choke and almost stall. That's gotten way better since I put the muffler back on and rebuilt the carb, but it's still there.
As I mentioned, the timing at idle is set at 6 deg BTDC, the mixture screw is at 3 full turns, and the carb has a fresh rebuild. I checked a plug (#3 if it matters) and the ground strap was a *little* white, but the insulator was a really nice light to medium chocolate brown all the way down- I think I have the mixture very nearly nailed. Points are gapped at .017. Other than the few little problems I listed above, it's running like a top. All I need now is a body that doesn't have rust bubbles on the frame!
Merlyn
Any suggestions, or should I just get a "Heep honking, I'm reloading" bumper sticker to explain the occasional sharp reports, and drive her till she drops?
PostPosted: Mon Mar 31, 2008 12:02 pm
Hesitates at part throttle tip in? Straining at high speed? Both symtems of the vacuum advance not working. Have you checked this out? The 6 degrees timing is correct. A quick check of this= disconnect the hose from the vacuum advance and with the timing light on the mark, rev the engine a bit graduallyand the mark should move up the scale with the speed increase. Then reconnect the vacuum hose and do this again-- the mark should jump up the scale much farther and faster than before. This is an easy and quick check of the advance system.
Two things that cause backfiring are, a bad "dump" valve on the air pump, and the coasting richer solenoid not working on the carburator. I'm assuming you still have the stock Hitachi carb.
