It is currently Mon Jun 08, 2026 7:58 pm
PostPosted: Mon Mar 03, 2008 3:18 pm
Can you tell me the length of the Input Shaft Length on both the LUV Isuzu 4spd and the PUP Isuzu 5spd.
I got a machine shop that says if that it is 6.5 inches, he can make an adapter to fit my 215 to it.
Thanks
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Mon Mar 03, 2008 4:28 pm
I happen to have my lovely engine out, right now. From the tip of the shaft to the inside base of the bellhousing, or the throwout bearing?
Mine is a 4 speed.
Tip to bearing:3.5"
Tip to bellhousing:6.5"
PostPosted: Tue Mar 04, 2008 9:11 am
Sweet than I am so much closer to making it work.
Would anyone like to bolt up a BOP(C) engine to the stock tranny? I have a machine shop that says they can make an adapter if the the input shaft was 6.5 inches long. The same as a BOP(C).
Thanks
Gareth
PostPosted: Wed Mar 05, 2008 3:00 am
Thanks
Gareth
That is interesting. I have a Buick 350. Would you find out how much the cost is? Could he do it for a Chevy small block, or just the BOP?
Users browsing this forum: Google [Bot] and 49 guests
