It is currently Mon Jun 08, 2026 10:29 am
 Post subject: oil pan gasket
PostPosted: Tue Feb 12, 2008 6:58 pm
has anyone here changed a oil pan gasket on a 4x4 luv without pulling the motor. i have a 79 that i just rebuilt the motor on and the gasket split in the rear after 2 weeks. i think it was a little cold out when i put it on, mabe 20 degrees.
 Post subject: Re: oil pan gasket
PostPosted: Wed Feb 13, 2008 12:10 pm
I have never done it, not sure if you can get the clearance needed. You might be able to unbolt it from the mounts and lift with a hoist to gain a couple inches. If anyone has done it successfully they will chime in eventually.
Chad
PostPosted: Fri Feb 22, 2008 8:49 pm
I have, it's a bioooch!!!!!!! You have to unbolt the motor mounts and jack up the engine/trans assy with a bottle jack ( at least that's what I used) by the transmission. But I'll say it again, it's a biooooooch!!! Tip--- get some 3m spray adhesive and spray the gasket, both sides before install. Ultra leak proof. Or you can do what I did and forget the gasket and get some Permetex Right Stuff gasket/sealant and just put enough on the oil pan and crank it down. I did that after blowing out my third gasket. Hasen't leaked since. Hope this helps. Good luck.
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
Users browsing this forum: Google [Bot] and 31 guests
