Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: In need of new head!
PostPosted: Tue Feb 12, 2008 12:14 pm
Hey guys, just found out the headgasket is blown between 3 and 4, well hopefully, and before I absolutely have to buy a new head, because its already been planed with like .0001 off or w/e is 10 thousandths, i need to check to see if its not on the back end of the engine, which it most likely is not.
anyway. i need a remanufactured head, and i have no idea where to get them, or just a plain brand new head.
i just want to get the thing. plop it back on the damn thing and LUV my truck again. :-)
that way i dont have to worry about valve seals, the cam, and blah blah blah.
anyone have any info on them and relatively how much they would cost?
and by the way, my truck has the g180. thanks guys
 Post subject: Re: In need of new head!
PostPosted: Tue Feb 12, 2008 9:52 pm
Is the head warped? If the head gasket is blown, it doesn't always mean the head has been damaged. This is not my area of expertise, but I'd make sure the head was damaged before I spent any money on a new one. A head gasket set is relatively inexpensive compared to a reman'd head, and you'll need a gasket set either way...
If you replace the head gasket you'll still have to insure the cam is set up properly and set the valve lash when you reassemble it. Tazman just did one of these on his truck, viewtopic.php?f=5&t=15673 and there are a lot of threads on this topic here on the site.
Good luck :D
PostPosted: Tue Feb 12, 2008 10:13 pm
I'm Assuming this is an aluminum head and I could be way off because I'm just now learning about this stuff in automotive classes.
But I'm tearing apart a g180 for the engine im rebuilding....
you can test the head with a die kit or have it pressure tested for cracks if the head is warp instead of shaving it they have a way of straighting out alumin head using a oven to get it back in shape and if it has a crack they can just cut it out and add more aluminum to it then machine back why this is all going on they can probaly clean the valves and grind the cam and you would have a good top end.
so you might look into pricing this out at a machine shop before just buying a new head or a used one from a junk yard.
these are from the local junk yard here in redding california
http://www.vikingtruckandauto.com/cgi-bin/search.cgi
211.05 for a 1980 chevy luv engine head
but like I said Im new and just giving my opion in the tiny knowledge I have gained sofar.
PostPosted: Wed Feb 13, 2008 2:23 am
the thing is we've already had the head machined. it was shaved 10 thousandths or w/e, and if its shaved too much more, it will end up pinging and i dont feel like buying octane booster to make the pinging go away. but anyway, its a recent rebuild back in january 07, the whole engine was completely done by my dad and i. and hes in indiana, he came out for a week and stopped by today and just said to buy a new head or reman'd and thats what i'd rather do, because he doesn't have the time. i love working on the thing, but its at the point right now where i just want to get something for it, put it on, and drive it. im tired of walking to work everyday haha.
i've been looking online and found a few hits, but it says electric fuel pump, and i dont know if mine is or not. im no good with the mechanics for this thing, except i know how to tear it apart and put it back together.
oh and thanks for that site for the parts. thats nifty, i wish our junk yards up here had a search function. haha
PostPosted: Wed Feb 13, 2008 3:02 pm
if you have a mechanical fuel pump, you can see it on the passenger side front of the head.... right by the distributor. You more than likely have an electrical fuel pump though.
PostPosted: Wed Feb 13, 2008 4:59 pm
I have a head, but im not 100% sure what engine that I had.
I THINK its good, but again Im not 100% sure.
The motor spun a bearing and the con rod cam apart, but the head didnt get damaged from it.
PostPosted: Wed Feb 13, 2008 8:16 pm
*looks hopeful* 8O :lol:
well lets say if you did have a g180 head, would you be willing to sell it/part with it and for how much? im up in washington so im sure freight would be pretty spendy. lol but as long as the thing is in good condition and will fit that would be awesome.
PostPosted: Wed Feb 13, 2008 9:14 pm
Id be willing to give it to you for the shipping & packing....
but lets make sure its what you want first....
I can take all the pics you want of it, but if there is a way to identify it before hand lets check first.
PostPosted: Thu Feb 14, 2008 4:12 am
right on. maybe someone on here can tell us of a way to identify it. haha if you knew the old block, there is the iron casting on the side, but then again you could of had a different head as well.
take lots and lots of pictures. i wonder how much shipping and freight would be.
PostPosted: Thu Feb 14, 2008 9:48 am
I was told the g200 was stamped into the head where the g180 doesn’t
PostPosted: Thu Feb 14, 2008 6:20 pm
I was just about to take some pics of it, but the batteries in my camara need to be recharged...
Where would it be stamped at? Its kind of messy right now, Ill have to take it through the car wash tomorrow....
There is suposed to be storms/ ice or some crap moving in tonight and tomorrow, its cold, windy and getting near dark outside right now. So if I know where to look then I can just spray that area with some brake cleaner and not have to be outside hunting for numbers with a flashlight.
PostPosted: Thu Feb 14, 2008 10:06 pm
i think i was told on the front of the head by the water tube
here found this from farmer joe
Quote:
the g200 head will have "G200" on the front of it. the g180 head will have an isuzu symbol on the front.
PostPosted: Fri Feb 15, 2008 6:21 pm
I didnt find anything stamped on it...sorry....
Did take some pics tho....
PostPosted: Fri Feb 15, 2008 6:24 pm
its wet because I just took it to the car wash, I can take some better pics....the flash is kind of bright on some of them....but my food buzzer was going off so I had to run back in the house.
PostPosted: Fri Feb 15, 2008 7:53 pm
i would say g180... you would see the g200 very easy if it was a g200
PostPosted: Mon Feb 18, 2008 7:18 pm
ok so i've decided im just going to replace the head gasket for right now, and possibly take it to a shop to have the valve guides redone, but then again im debating.
but i have a question about tearing it down. i've gotten all the headbolts out, and took off the exhaust manifold, but am leaving the intake on, but the head barely moves.
im thinking, that right next to the timing chain, there are 2 bolts that i might need to take out? but im not sure, im guessing i do anyway.
and to keep the timing chain up, what should i do? thats also why it won't budge beacuse i realized i haven't taken out that big bolt that goes into the chain sprocket. hahahaha
should i use zip ties. or does the tensioner save me that trouble?
thanks.
PostPosted: Mon Feb 18, 2008 7:58 pm
zip ties or what ever you can make do :lol:
PostPosted: Mon Feb 18, 2008 9:09 pm
thanks.
yes they need to come out and use the zip ties, i use 3 at 9 12 and 3 on the sprocket as if it was a clock
PostPosted: Mon Feb 18, 2008 9:53 pm
so just put a tie through each of those slots and thats good? what if there is too much slack and it skips a tooth or something? ack
PostPosted: Mon Feb 18, 2008 10:47 pm
just be carfull is all , never had one slip on me yet
Users browsing this forum: No registered users and 69 guests
