It is currently Tue Jun 09, 2026 12:18 pm
PostPosted: Tue Feb 05, 2008 9:46 pm
where the tube goes to the exhaust from the intake. in porterville ca by the way
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Tue Feb 05, 2008 9:57 pm
Do you mean the cooper tube that one end screws into the intake and the other side into the exhaust manifold?
PostPosted: Tue Feb 05, 2008 11:11 pm
if you need the manifold i have one :D
but if you need the copper tubing... i tossed it :cry:
PostPosted: Wed Feb 06, 2008 10:27 am
The tube is only steel.
PostPosted: Wed Feb 06, 2008 8:30 pm
PM sent.
PostPosted: Thu Feb 07, 2008 9:16 pm
no i dont need the tube i managed to get one awhile back but i was finnaly able to get the whole shabang out but it took 3 guys 2 48" pipe wrenches with cheater bars and a big ass torch to get the steel from the dam aluminum manifold. it left the threads in the manifold and managed to crack it in the process. rondog ill check shipping costs and get back to you
PostPosted: Thu Feb 07, 2008 11:36 pm
Ok, so it's like a penny. It only appears to be copper coated
 Post subject: Re:
PostPosted: Sun Feb 10, 2008 7:47 am
I think its actually some sort of low grade stainless steel. Same stuff they make stainless exhausts out of.
Bob.
