It is currently Mon Jun 08, 2026 5:21 pm
PostPosted: Sun Jan 27, 2008 1:23 pm
Had backup lights, thought it was just a bad ground, fixed THAT problem, still no backup lights! Where is the switch located that turns on the lights when we put it into reverse? Specificaly, I mean, as it looks like we need to replace it. I don't want to have to tear the whole cab or tranny tunnel apart, just get in and get out and replace it. Thanks!!!
PostPosted: Sun Jan 27, 2008 3:17 pm
PITA Old Fart
The actual switch is on the transmission and gets activated when you put the transmission in reverse.
PostPosted: Sun Jan 27, 2008 5:25 pm
Looks like it's on the driver's side tailshaft housing...
PostPosted: Wed Feb 06, 2008 8:20 pm
Thanks very much! I hope mine is the same. I dunno why, I thought it must be up near the shift lever, looks like I was wrong, but this should be much easier to get to! Now, if I can JUST find a new back-up light switch... :(
