It is currently Mon Jun 08, 2026 12:54 pm
 Post subject: help truck wont fire
PostPosted: Sun Jan 13, 2008 6:52 pm
My truck is 79 4x4 I cant seem to get it to fire what steps can i take to troubleshoot this.
PostPosted: Sun Jan 13, 2008 7:14 pm
You might want to do a site search for this, there have been several recent no-start threads.
If you don't have a factory manual, you might want to invest the $10-20 on ebay to pick one up. They are very helpful in T-shooting these trucks.
So, with that out of the way, what have you checked? Have you done recent work to the truck? Do you have 12V from the key to the coil? Is it an AT or standard?
More info would help us help you...
PostPosted: Sun Jan 13, 2008 10:36 pm
How have you checked for fire? It seems like everytime I had a problem like this on mine, it ended up being my coil wire, from the coil to the distributor. I would start there and work backwards. Check the coil for spark, then the wiring going to the coil, and so on until you find where you have power, then the last place that didn't have power is usually your culprit.
