It is currently Mon Jan 21, 2019 11:07 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Jan 12, 2012 3:52 pm
I just ordered the disc brakes from a shop in Oklahoma.
$100.00 a side and $40.00 shipping.
He said it would take a week for delivery.
Looks like I'll finally get my disc brakes!
PostPosted: Thu Jan 19, 2012 9:15 pm
Got the disc brakes in today.
Donor was 1979 2 wheel drive.
They look great.
Brake swap on Saturday!
PostPosted: Thu Jan 19, 2012 11:06 pm
Sweet!
PostPosted: Sun Aug 19, 2012 6:46 pm
im going drum to disc, if i may ask, i have the trooper backing plates, i havent gotten rotors yet, i just want to know if i have to have get a hub to go with the rotor? or do i get new studs and press them into the rotors?? im a fresh new build
PostPosted: Tue Aug 21, 2012 5:05 am
Australian LUV Guru
Trooper rotor bolts to disc brake style Luv Hub.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Jun 05, 2013 2:59 am
Brakes square measure garbage on my '75 LUV...so about to upgrade them to the later vogue disc brakes...
To do so, I've ought to swap the hubs up front. square measure Trooper hubs the same?
I detected a rumor that the Trooper ventilated discs will slot in the LUV disc calipers.
Also, anyone grasp if the thread pitch of the brake lines square measure an equivalent for all? There square measure stainless-steel brake lines for Trooper
2013 MERCEDES BENZ SL-CLASS
PostPosted: Sun Jun 09, 2013 12:09 am
so guys i have a problem, im going to switch to trooper rotors and calipers.
on rockauto for an 86 trooper they have a bunch of rotors listed with a 16.6mm min thickness.
they have some listed from 11/86 to 6/87, (not sure if they are different then pre nov/86) the standard ones are the regular size 16.6mm min, but there is a heavy duty/ high performance, that say minumum thickness 20.6mm.
im not sure if the high performance rotors are able to fit or not, if not i will get a set of 85 rotors to be sure they fit.
btw anyone who wants to make the switch rockauto has the rotors and calipers (loaded or unloaded) for CHEAP.
2002 Acura MDX the wifes daily
PostPosted: Mon Jun 10, 2013 1:23 pm
The rotors that are listed "Fr 11/86 - To 6/87; Front" are actually 87+ rotors and I doubt they would fit. If you click the part number it will show what years they fit, and anything that says it will fit a 91 Trooper is for the 10 bolt front axle and not likely to swap as directly as the ones that are listed as "To 11/86". (Which means manufactured before 11/86)
That said, I don't know if it is possible to swap the bigger rotor, brackets, and calipers from an 87-91 Trooper and get an even bigger upgrade... could be??
PostPosted: Mon Jun 10, 2013 10:23 pm
i will bring a ruler and a micrometer next time i hit the yard, probably the weekend after next and see what i can find out.
PostPosted: Tue Jun 11, 2013 5:33 am
Australian LUV Guru
Some quick research turned up these spec's for Pup/Trooper/Rodeo/Amigo front brake rotors, all rotor's below should be a direct fit to your existing hub. As for dust shield fitment and caliper fitment im still unsure.
81-87 250mm diameter x 18mm thick
88-91 257.5mm x 22mm
92-97 280mm x 26mm
PostPosted: Tue Jun 11, 2013 11:18 am
The 92-97 rotors and calipers could be fun, those are plenty big. I just picked up a 95 Trooper and I can say that those brakes get it from go to whoa pretty quick. Plus, there are sources for slotted and drilled rotors for those. That would pretty much require 15 inch or larger wheels though.
I did a quick bit of checking on planetisuzoo.com and found plenty to support the upgrade from 88-91 brakes to 92-97, but not a direct link from 84-86 Troopers, which would connect it to LUVs. Looks fairly promising though and I am pretty sure I saw info to upgrade my 86 to 88-91 rotors some time ago.
I went ahead and sent a PM to JLEMOND over at the 'zoo. He'll know If any of the early 1st gen Trooper stuff will swap for the the later 1st gens. If so, that could be a killer front brake upgrade for any LUV.
PostPosted: Tue Jun 11, 2013 1:51 pm
awesome that will be some useful info 8)
there are so many places out here that having great brakes would come in handy :lol:
if its a matter of bringing over the brackets and such from the later models and a 15" wheel to clear them im willing to grab a set and see how they fit.
PostPosted: Tue Jun 11, 2013 2:20 pm
92-97 280mm x 26mm
The specs from '81-'87 can't be right. I just bought a set of rotors for my '83. They're non-vented, but the '84-'87 rotors are vented.
PostPosted: Tue Jun 11, 2013 4:39 pm
Looks like the bolt on upgrade path stops at 10/86. The 87-91 and 92-97 brake parts will not bolt right onto the LUV steering knuckle. According to JLEMOND The caliper brackets are different, so it would require machine work to make this swap happen.
It might be possible to swap the knuckle from a later truck over but the bearings will need machine work and the lower ball joint will need attention too. If the hubs are swapped over then you need the axles too, then the center section and the front diff, and it just snowballs from there.
PostPosted: Tue Jun 11, 2013 5:41 pm
basically if you want a full front end swap the bigger brakes are for you :lol:
 Post subject: Re:
PostPosted: Wed Oct 28, 2015 6:17 pm
OzLuvTrucker wrote:
The Trooper rotors feel half the weight of the Luvs solids. Ive just completed the conversion and theyre totally compatible. Its so simple i dont know why i hav'nt seen this done before.
Step 1 remove hub from Luv.
Step 2 unbolt Luv rotor from hub.
Step 3 bolt Trooper rotor to Luv hub.
Step 4 fit hub& rotor back on Luv.
do you think this disc brake swap is the same on the 2wd 1980?
My luv project
https://youtu.be/wd5eCjrNL6U
PostPosted: Tue Nov 24, 2015 4:30 pm
did you need to bring over the mounting hardware for the trooper calipers??
I have a new in box set of calipers for 84-87 pup and the mounting holes are about 5 3/8" apart, my luv caliper mounting holes are about 6 1/4" apart. I would really like to upgrade to the calipers and the new pads I have for them
edit: nevermind, I saw I need the caliper brackets too. gotta hunt those down
Users browsing this forum: Google [Bot] and 7 guests
