It is currently Tue May 26, 2026 8:44 am
 Post subject: Rear Window Gasket
PostPosted: Mon Dec 31, 2007 1:01 pm
Has anyone done any research into getting these manufactured, or found a suitable replacement?
I've been looking at both of them in my '78 w/slider and the '75 with a better slider (flo-thru?). They aren't the same, and I'm guessing the one for the stock solid glass is also different.
I've had good luck dealing with Metro rubber in the past, is there any interest in maybe having these made? I know that the old VW bus windshield gasket works for lots and lots of 'custom' applications on older cars, it would obviously need to be cut down for a rear window on a Luv.
Ideas? Has anyone found something that works?
PostPosted: Mon Dec 31, 2007 1:29 pm
This is as far as an earlier thread went...
http://forums.luvtruck.com/viewtopic.ph ... r&start=40
PostPosted: Mon Dec 31, 2007 3:06 pm
i had to put a f*%d rear window rubber it was a bit to big but it worked i cut it to fit not perfect
dangerous-toys4life
75 k-5 2x
94 king cab
Users browsing this forum: No registered users and 70 guests
