It is currently Fri Jun 26, 2026 9:33 am
 Post subject: fixing the trans
PostPosted: Sat Dec 29, 2007 3:54 am
ok i got the stuff to fix the trans i got the hole clutch kit with pilot,presher plate any thing you all can say to help all info good or bad ok i was going to also put the 5-speed in at the same time but it is the one that has the remote on it and i need to kut the floor about 6" back and move the fuel lines i will see when i get the trans out i got the whole kit for 105.00 dam good deal
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Dec 29, 2007 11:42 am
thats a real good deal :D
PostPosted: Sun Dec 30, 2007 10:08 pm
got the trans out and again i did not need to pull the motor with it i am going to put the clutch kit in tomorrow and drive it and then this summer i am going to put the 5speed and disc rearend in after i save up sum $$$ for sum parts that i need to complete the job right :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Dec 30, 2007 11:03 pm
Australian LUV Guru
Image The remote gearstick unbolts and the stock luv stick bolts in, no need to cut the floor.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Dec 31, 2007 8:51 pm
i got the tool to pull the pilot bearing out and that sun of a snitch will not come out i put wd-40 and i am going to let it sit over night and try tomorrow and now i need a flywheel mine as sum cracks in it and i got the trans out so i will do it right this time ok laters to all and happy new years :microwave: :drinking: :popcorn: :smt021 :smt020 :smt028 :smt043 :smt050 :smt068 :smt067 :smt066 :smt064
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Tue Jan 01, 2008 1:41 am
Never pulled the pilot in a LUV, but on others I've packed the pilot hole full of grease and used an appropriate sized wooden dowel or piece of round stock to just slip in the pilot hole and forced the bearing out by using a shop hammer and tapping on the dowel.
PostPosted: Tue Jan 01, 2008 3:25 am
i did that lol and the little ring popped of and the grease came out :( it was funny so i went and got the tool and it is just rusted :x :? in there but i will win in the end lol i am getting a new fly wheel for $60.00 so that is a good deal $170.00 total for a new clutch set up i luv it and next is the rearend
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Tue Jan 01, 2008 9:49 am
I cut one out with a small air hammer once.
PostPosted: Tue Jan 01, 2008 3:22 pm
yep thats my next option i am going to get to it in a bit i will let you all know :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: fly wheel bolts specs
PostPosted: Wed Jan 02, 2008 7:30 pm
well i got it out it had to be cut and i also used a dremel it had gotten hot and welded it self but i got the new one in and my new fly wheel will be in tomorrow after noon and on the 5 speed the shifter plates are not the same so i will still need to cut a hole but no big deal i have been cutting up trucks and cars for years and any one know what the torc specs are on the fly wheel bolts the 6 that hold the fly wheel on lol :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Jan 03, 2008 3:31 pm
i need the torc specs for the fly wheel any one got them thanks for all your help guys i will be driving my luv hopefully by the weekend after 8 months 8) :P then i need to but new brakes on the rearend
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Jan 04, 2008 5:26 pm
i got it done she runs good and quiet
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Jan 04, 2008 7:38 pm
Probably too late but torque specs for flywheel are 69 ft lbs.
