It is currently Sat Jun 27, 2026 4:03 pm
PostPosted: Sat Dec 01, 2007 11:42 pm
I have a 79' that had passed all test except the functions test of EVAC (pressure leak in fuel line). Can anyone help me in the procedure to finding out where this leak is and what tools i can use to pressurize the system? Thank you. :D
PostPosted: Sun Dec 02, 2007 9:04 am
Fuel cap. And check out the little three way valve on the right side of the fire wall. It's next to the washer bottle. It has 1 hose to the oil pan, 1 to the vapor tank (behind the cover on the left front corner of the bed) and 1 to I think the air cleaner.
That vapor tank could be cracked or broken too. Check all the lines in and out of your fuel and vapor tanks. They all probably need to be replaced anyway. Good luck.
PostPosted: Sun Dec 02, 2007 5:06 pm
Thank you very much :D Where can I find the replacement lines and all if it comes down to that?
PostPosted: Sun Dec 02, 2007 6:54 pm
It's all just fuel line. Go to your local auto parts store. I doubt the steel line has anything wrong with it.
PostPosted: Mon Dec 03, 2007 10:47 pm
I doubt its that, the line is pretty new, i don't know about the steel line.
