It is currently Mon Jun 08, 2026 3:07 pm
 Post subject: Transmission question
PostPosted: Mon Oct 15, 2007 8:34 pm
Is there any other types of automatic transmissions that bolt right on to the stock motor? My engine runs fine but the transmission went out on me again. I had to push the truck out of the driveway in reverse and then push it forward a little before it would go on it's own. I got about 2 miles down the road before it just gave up on me. Had to leave it on the side of the road this morning.
PostPosted: Tue Oct 16, 2007 6:39 am
The Impulse with the G200Z motor has a 4 speed auto that will bolt up.
The turbo and 2.3L impulse also has a 4 speed auto but the flex plate and crank bolt pattern are different.
Any vehicle with a G180Z or G200Z the trans will fit.
Any vehilce with an 4Zxx motor will bolt up to your stock motor but the crank pattern is different. its 8 bolts instead of 6 bolts in the GxxxZ motors.
Bob.
