It is currently Tue Jun 09, 2026 1:31 pm
 Post subject: Brake light stays on?
PostPosted: Tue Sep 04, 2007 10:45 am
I have been having trouble with the brake light staying on. I suspect it has something to do with the emergency brake lever and the pin that the lever comes against when the brake lever is pushed back down. I have changed the pin connection and tried adjustment of the pin on the emergency lever shaft with no success. I have resorted to just taking the brake light bulb out of the dash, which isnt my preferred fix. Any words of wisdom?
Thanks!
Todd
Puyallup WA
1978 long box LUV
PostPosted: Tue Sep 04, 2007 1:23 pm
Check underneath to make sure one of your e-brake cables isn't hanging up and not releasing all the way... and make sure your brake fluid level is up.
If niether of them is the problem, then you have a short somewhere, most likely underneath your truck.
