It is currently Mon Jun 08, 2026 4:26 pm
 Post subject: Plug wires and Mice
PostPosted: Sun Aug 26, 2007 3:30 pm
I have found a 78 stock luv was a farm truck and mice have eaten the plug wires if any one knows the firing order and wire lay out it would felp me reserect this truck
PostPosted: Sun Aug 26, 2007 3:37 pm
The firing order is 1342. # 1 is at the front of the eng. and #4 is at the rear.
#1 should be marked on the dist. cap. But it would be best to crank the eng. to #1 compression stroke and take the cap off and look at where the rotor is. That is where the #1 wire will go. The dist. rotates counter clock wise. Good luck. If the truck has been sitting a long time ( like years) you'll probably need fresh gas and maybe need to drop the tank and have it cleaned out. They tend to rust.
PostPosted: Mon Aug 27, 2007 2:39 am
PITA Old Fart
Quote:
They tend to rust.
Yeah...just like Dolly Parton tends to have a little cleavage. :lol:
PostPosted: Mon Aug 27, 2007 6:12 am
ya just a little :D
