 Post subject: Head lights
PostPosted: Thu Jul 05, 2007 3:41 pm
How hard is is to convert a 2 head light set up to a 4 light set up?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Thu Jul 05, 2007 6:28 pm
I think the radiator core support is different. If you can do it you will need a smaller grill also.
PostPosted: Sat Jul 07, 2007 5:02 am
Australian LUV Guru
Everything from a 4 lighter will swap into a 2 lighter.
All screw holes are ther for the light buckets, light bezels and grill, all that you have to modify is the wireing. I have 100watt globes in each light, two outer lights are in use on low beam, all 4 lights are used on high beam.
1980 4x4 KBD40 ISUZU/Chev Luv
