It is currently Sat Jun 27, 2026 2:47 pm
 Post subject: brake noise
PostPosted: Fri May 18, 2007 4:29 pm
I was hoping someone could tell me why my brakes are making a rubbing noise, I thought the brakes may be bad and I was right I changed them, but that didnt fix the noise so I thought maybe the bearings were worn I put new bearings in and I still have that rubbing sound if I turn the wheel just a little to the left it goes away anyone have any ideas?
PostPosted: Fri May 18, 2007 5:22 pm
Australian LUV Guru
Front or rear :?: Sounds like the front calipers are not releasing, or rear shoes are draging. Do the rotors/ drums get hot after driving :?:
PostPosted: Fri May 18, 2007 7:34 pm
umm, i didn't(not forgot i never forget) to adjust the the rear brakes after replacing them, and before they self adjusted they made a funky noise??
PostPosted: Sat May 19, 2007 9:15 pm
I forgot to lub the bolts on the front, that I hope will fix, your right they are not releasing all the way, thanks
PostPosted: Sat May 19, 2007 9:55 pm
:smt023
