It is currently Sun Jun 28, 2026 8:28 pm
 Post subject: Dual crank pulley 1.8
PostPosted: Tue May 08, 2007 7:03 pm
Looking for a dual crank pulley for a 1975 1.8. Thank's Ron
PostPosted: Tue May 08, 2007 7:35 pm
i dont think there ever was a dual crank pulley on the luv engine.
what are you needing a double pulley for?
PostPosted: Tue May 08, 2007 8:19 pm
Would the A/C LUV's have one ? Maybe another isusu motor has one you could tear off that would work.
-Austin
PostPosted: Tue May 08, 2007 10:32 pm
Yes. The A/C trucks used a 2 pulley system off the crank.
PostPosted: Tue May 08, 2007 10:37 pm
did the 75 have AC? a stock 75 will have a non-crossflow engine in it.
what engine do you have in the truck?
PostPosted: Tue May 08, 2007 10:44 pm
Yea. Mine is on an 80 cross flow 1.8. I don't know if any of the old engines came with air.
PostPosted: Wed May 09, 2007 6:57 pm
That's right A/C Calif starting to heat up. How many engines did a 1975 have all I know is a 1.8. The truck I have is a morphidite the vin number on the door post & frame is for a 1975 and this truck has disc brakes and auto trans! Maybe late 75. So maybe some one can help me out is the 1975 and 1976 the same engine? Ron
PostPosted: Wed May 09, 2007 7:56 pm
My 79 came with the 2X50 system....
2 Windows down at 50 Mph...
yuk yuk yuk
PostPosted: Wed May 09, 2007 8:34 pm
Is your intake and exhaust on opposite sides of the eng., or on the same side?
Users browsing this forum: No registered users and 84 guests
