It is currently Mon Jun 08, 2026 4:43 pm
PostPosted: Mon May 07, 2007 7:44 pm
It's charged up and blowing ice cubes.... but.... It (the compressor) cycles on and off. It will run and get very cold for about a minute or two, then for another minute or two, it will shut off and start warming up. Then it kicks on and gets cold again. It will do it while stoped at a light or while driving. Eng. or road speed doesn't matter. Could it be overcharged? My buddy just hooked the bottle to the low side and let it have what it wanted.
 Post subject: .
PostPosted: Mon May 07, 2007 8:19 pm
No expert, but I'm a lucky Google'r sometimes.
Found this while I was doing some pre-reading before attempting to get mine going.
Question:
With the engine running, the temp control on full cold and the A/C control on A/C or MAX A/C, the compressor clutch will pull in and run for about 5 to 10 seconds then drop out. I'll wait for about 30 seconds and then it does the same thing again. The compressor sounds good when running, it just won't stay engaged.
Response:
This sounds like a classic example of low refrigerant charge. When the compressor engages, the high side in the system goes up, while the low side goes down -- this is normal. For a fully charged system, the low side will hover around 28-38psi, and the high side will run 150-200, sometimes higher, depending on temperature and humidity. When the system charge is low, the low side generally runs down below the low-side cut-off switch, and the compressor clutch is disengaged to prevent damage.
A typical charge and leak test will run between $85-135, depending on the shop. This would include a charge, an electronic leak test, and if necessary, a dye installed in the system (unless it's already there). Hopefully, the leak is minor and can be fixed at the same time. Some very small leaks are often found on the next visit.
If leak is found to not be the problem, I suppose overcharging could present trouble from the other end of the spectrum.
FIAA: Color Guard
 Post subject: .
PostPosted: Mon May 07, 2007 8:59 pm
After more reading, could it be an A/C evaporator temp sensor?
FIAA: Color Guard
PostPosted: Mon May 07, 2007 10:08 pm
Thanks, 79. 8)
Users browsing this forum: Baidu [Spider], Google [Bot] and 56 guests
