It is currently Mon Jun 08, 2026 12:54 pm
PostPosted: Wed Apr 25, 2007 1:13 pm
Our local shops and the dealer say they can not get a valve cover gasket for a stcok 1974 motor. Does anyone know of any sources?
Bruce
PostPosted: Wed Apr 25, 2007 2:12 pm
This is available from several sources online. I use http://www.rockauto.com quite a bit. Here is the part number they list for your application:
FEL-PRO Part # VS50165A (includes side cover gasket)
Current price on this is $4.25 :)
http://www.napaonline.com also has an online source, add FPG (Fel Pro Gasket) to the same PN above. Their cost is $6.49.
Good luck, there are lots of reputable sources out there. NAPA is nice becuase you can order it online and pick it up at the nearest store. I think Autozone does the same thing, but I'm not a fan of their gaskets...
PostPosted: Sun Apr 29, 2007 10:18 pm
Thanks for the tip on the gaskets.....time to go shopping.
Bruce
PostPosted: Sun Apr 29, 2007 10:31 pm
you mean the rocker cover? if so i have 7 nos here on my desk... i could send a pic if needed
PostPosted: Mon Apr 30, 2007 2:35 am
Soo, rocker Cover, same Thing as a valve cover right, just a funky english(british) translation, or is there some specific thing that makes this a rocker cover???
PostPosted: Mon Apr 30, 2007 8:46 am
yes just depends on the parts manufacturer... looked closer at the NOS parts and it did say (valve rocker cover) genuine parts isuzu motors limited
PostPosted: Mon Apr 30, 2007 7:58 pm
I ended up getting the set locally. The large main gasket is very straight but the Rocker/Valve cover has a sig sag for looks like the head bolts. I'll assume that the Felpro product VS50165 will work. Any suggestions are welcome. The cover leaks pretty bad.
bruce
PostPosted: Mon Apr 30, 2007 8:08 pm
Hey ctmandu, is the cover gasket the same for the later motor? I need one too...
PostPosted: Mon Apr 30, 2007 8:13 pm
Different gasket for the later years.
