It is currently Wed Jun 24, 2026 8:13 am
 Post subject: fusable links???
PostPosted: Sun May 06, 2007 12:38 am
on the bong
Alright, I had lost my key, I had to move my truck, hotwired ignition on, and tryed to jump the starter. It started I flinched and shorted somthing out. All fuses are good getting power, but my ignition dosn't have a constant any more. I know I can jump the ignition with a positive constant wire, but I'd rather fix it the right way. Any help?? My starter and alt are new and under warranty, so I'll pull those to make sure they still work tomarrow, then I can finnaly put in the new crome alt braket also.
PostPosted: Sun May 06, 2007 10:11 pm
on the bong
I found it Its off the smaller wire on the positive terminal if anyone has an issue with it. I had no costant power inside of car, and this was the issue I pulled it and pluged it back in. and everything worked again.
Users browsing this forum: Google [Bot] and 49 guests
