It is currently Tue Jun 09, 2026 1:33 pm
PostPosted: Sun Apr 15, 2007 1:52 pm
I am replacing my timing chain set up to try and get my 80 luv 4x4 driving agian and i need all the help i can get....i am not very good at doing stuff like this and i do have a friend to help( has not done one either) but we have a haynes manual to help......please if there is any thing you can say to help that would be great.....this is the only day i can do this unless i go w/out the dirty luv for another week till sunday.........thank you for all!!!!
1980 chevy luv,rubbn hard on 30/950/15's mud terrain sxt by dean tires, spraypainted black w/orange homemade brush guard, crome allied 97 15"s with black bead lock mock rings, 3" boddy lift (need more than that) and just trying to make kinda killer
PostPosted: Sun Apr 15, 2007 2:24 pm
Hey Nasty Nick!
I hope you are having fun! My timing chain broke last year and I replaced it. I have a few posts related to it. Type in timing chain with "Dottie" as the author in the search feature at top and read those threads. There are some good tips that people gave me. Like how to get the crank shaft bolt off if you haven't done so already. Also, hopefully you had the #1 cyclinder at top dead center when you started taking it apart. Good luck!
Dottie
PostPosted: Sun Apr 15, 2007 2:40 pm
Hey Dottie, thanks for the help... I have one big question, does the head have to come off to get at the timing chain/gear and all that?
PostPosted: Sun Apr 15, 2007 2:59 pm
No.
PostPosted: Sun Apr 15, 2007 3:11 pm
I would recommend you read the manual a couple of times before digging into it. Also do the search like Dottie mentioned and study that as well. With all of that info you should be fine.
 Post subject: thaks again!!!
PostPosted: Wed Apr 18, 2007 11:10 am
Hey i thank everybody for all the help!! i ended up not jumping into the timing chain set up ...looked like more then me and my friend could handle......but i started to look deep in the dist. cap and noticed a frayed wire (condenser??) so looked deeper and noticed that my points were hitting lower then it was supposed to ...it ended up busting through on one side and really not doing anything sooooo .......i took back the $68 timing chain set up and bought $20 points and condenser....put that in and set the gap to 16-17...then tunned carb. put in new anti freeze (had it) then checked timing...timing still jumps around but now its w/ in specs...it jumps between 8* and 12*........longer story cut shorter, it runs ......and it runs a little better then it ever had since i have had it...(plus the new clutch helped)......hahah NasTY
