It is currently Mon Jun 08, 2026 12:54 pm
 Post subject: Electric Choke
PostPosted: Wed Mar 07, 2007 5:15 pm
Is it possible to just unplug my electric choke? Will the truck keep running? It isnt working properly and I think it starts to flood the engine, after it is warmed up. I bought a Weber from CARBSUNLIMITED yesterday so I only need a temporary fix for a couple days.
PostPosted: Wed Mar 07, 2007 6:55 pm
You can unplug the choke, but if it is flooding your carb after it is warm then it is staying closed all the time, which is what it will do when you unplug it. You can loosen up the screws that hold the choke on and clock it so that the spring has no tension on it and the choke is open when cold. It will just have to warm up with your foot on the gas.
