It is currently Mon Jun 08, 2026 2:08 pm
 Post subject: smog sh!t
PostPosted: Sun Feb 18, 2007 11:35 pm
i would like to know if there are any ill effects to taking all that crap (smog) stuff off of my engine. Ive already taken off the pump, the brackets to the pump, and the thingy that goes above the exhaust manifold.I bought some pipe plugs from AutoZone and put them on with a little Loctite, so what else needs to go? I want the engine to look clean, not like a premature baby with all kinds of hoses and tubes attached to it. Also, i want to buy a weber carburetor, so if anyone has any ideas, tell me. Thanks
PostPosted: Mon Feb 19, 2007 9:28 am
if you buy a weber you can get rid of alot of the vac lines and the air cleaner that helps alot im take all my wireing loose and reruning it though
some silver and red duct work i made up to match inside and out of the truck
92 gmc on 35/12.50/15
81 luv on 31/10.50/15
PostPosted: Tue Feb 20, 2007 12:08 am
I'd leave the EGR, it does help you get a little more advance on the timing for a little more power. Without it my 79 was hard to keep from pinging on any kind of long pull up a hill.
