It is currently Tue Jun 09, 2026 2:07 am
 Post subject: moisture
PostPosted: Thu Feb 01, 2007 8:09 pm
Has anyone had trouble with moisture in dist. Mine sets in a garage an get moisture in dist., any ideas on how to fix this?
Thanks,
PostPosted: Thu Feb 01, 2007 8:19 pm
I have seen this but however never heard of a cure, anytime metal gets close to or below freezing it sweats. Also condensation and moisture just in the air can lead to this. Maybe someone else can inform you of a cure...
PostPosted: Thu Feb 01, 2007 9:07 pm
If your cap is not vented you can drill a 3/16 hole between the tirmanils that will let air flow
hope that helps
terry
PostPosted: Thu Feb 01, 2007 9:28 pm
If you do, be careful when you wash the truck...
PostPosted: Thu Feb 01, 2007 9:48 pm
If it sets in the garage for long periods pull the cap loose,as for drilling it that can be done to but i would use no more than 1/16" and drill down low
PostPosted: Sun Feb 04, 2007 8:37 am
Maybe a hair dryer?
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sun Feb 04, 2007 8:41 am
WD40 also helps control moisture and it is not a insulator. Just spray it inside the cap.
Users browsing this forum: No registered users and 59 guests
