It is currently Mon Jun 08, 2026 6:35 pm
 Post subject: Clutch Replacement
PostPosted: Sat Feb 24, 2007 12:47 pm
Hey, I plan on replacing my clutch next weekend and have a few questions. Can you replace the rear main seal without dropping the oil pan? I bought the complete clutch kit which includes the disc, pressure plate, throwout bearing, pilot bearing and alignment tool. I read on an earlier post that there is another bearing in the tranny that should be replaced while doing the clutch, does anyone know what this bearing is called, so I can get one from NAPA? Thanks again for all the help!
 Post subject: help us here!
PostPosted: Sun Mar 04, 2007 12:26 am
i too could use the answers to these questions like the other bearing to replace and if i can use the bigger cluth with the smaller fly wheel i have a 79 and i think the 80 4x4 is bigger clutch like 9"
PostPosted: Sun Mar 04, 2007 2:03 am
I know my luv made a really whiny noise after driving 55 for a while and then cruising to about 30mph in traffic it kind of got annoying I think it was the input bearing.
PostPosted: Sun Mar 04, 2007 3:01 am
I just got a clutch pack from NAPA. It was $104 complete with a pilot bearing, throwout bearing, pressure plate, clutch disc, and alignment tool. I replaced the flywheel and the whole job took about 3 hours. Pretty easy really. I think 4wd LUVs use a different flywheel than a 2wd, but I am not sure.
Users browsing this forum: Google [Bot] and 50 guests
