It is currently Tue Jun 09, 2026 5:39 am
 Post subject: Hooking up a Tach
PostPosted: Fri Feb 02, 2007 10:57 pm
How do i determine the negative side of the distributor or what wire on a 1979 would i tap into?
PostPosted: Fri Feb 02, 2007 11:17 pm
Hook the wire on the negative side of the coil. Thats the small wire that runs
from the coil to the distributor.
 Post subject: Tach
PostPosted: Fri Feb 02, 2007 11:20 pm
Thanks a lot, this is my fist Luv Truck and don't know much about them yet.
PostPosted: Fri Feb 02, 2007 11:31 pm
Most coils I've seen have the positive and negative terminals marked.
'78 1.8L 4-speed Fleetside
Image Image
