It is currently Wed May 27, 2026 1:08 am
 Post subject: driveline yoke
PostPosted: Tue Jan 09, 2007 9:20 pm
i have a cable clutch 4 speed i believe it a 81 tranny.....anyways i dont have the drive yoke that goes into the tranny and i need to know if the splines are any different for the 78 through 82 luvs.....like i counted 18 splines on the tranny........so my question is is there 18 teeth on the tranny for the 78-82 cable clutch :?: :?: :?: luvs
Arquing with me is like running in the special olympics, even if you win your still retarded.
PostPosted: Tue Jan 09, 2007 11:18 pm
help me its the last piece of the puzzle for the tranny swap
PostPosted: Wed Jan 10, 2007 10:23 am
i need this last piece bad
PostPosted: Wed Jan 10, 2007 4:07 pm
HUh. If I end up replacing the crankshaft i could have that info for ya because I'd be removing the driveline, tranny, and flywheel. That won't be for a week at least.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Jan 10, 2007 9:47 pm
i need this part bad will pay good money.........just the yoke for the tranny
PostPosted: Thu Jan 11, 2007 12:47 am
I might have an extra one I'll look tommorow and let you know.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Jan 11, 2007 12:58 am
when i put the 77 luv tranny in my 84 pup, i had to put the luv yoke on the pup driveline to make it work.
so if your going with a later model trans, youll need the later model yoke also. the u joiny is the same though. so you can just put the later model yoke on your early model luv driveline.
PostPosted: Fri Jan 12, 2007 2:17 am
??????????? please i will pay good guys
PostPosted: Sat Jan 13, 2007 12:35 pm
its a 18spline yoke and i need it this is my daily driver down still yet so does anyone got one
Users browsing this forum: No registered users and 62 guests
