It is currently Tue May 26, 2026 1:00 pm
 Post subject: pics of the hood puller?
PostPosted: Sat Jan 06, 2007 7:31 pm
anyone have a pic of the handle, all I have is braided wire and a vise grip, for mine..LOL does it go to the dash? or what..
also, I got my luv and the right blinker works and the flashers, but the lever wouldn't go down to signal left, so I sprayed WD-40 in the column and worked the lever and then it went down, but still no flash, do these flash fast to let you know a bulb is out?
PostPosted: Sat Jan 06, 2007 7:47 pm
Won't have a picture until tomorrow. But it is located under the driver side of the dash on the side of the kick panel wall.
PostPosted: Sat Jan 06, 2007 10:16 pm
It's just a little steel lever that pivots from the top. It pulls toward you when your in the seat.
 Post subject: Hood release
PostPosted: Sat Jan 06, 2007 10:54 pm
Yep
It's located driver side panel uder dash.... kind where most cars E-brake release used to be.
You could probably Southern engineer one out of low quality butter knife handle, spring, drill and bolt :D
FIAA: Color Guard
PostPosted: Sun Jan 07, 2007 9:27 am
It's the little black handle.
http://new.photos.yahoo.com/johnboyp196 ... 2383149603
PostPosted: Sun Jan 07, 2007 12:51 pm
Johnboy wrote:
Link failed :(
PostPosted: Sun Jan 07, 2007 8:00 pm
It's probably set to private. My hood release works, but all it is, is a braided wire on the inside fire wall with a vise grip attached.
PostPosted: Sun Jan 07, 2007 9:49 pm
Sorry about that it was set on private. Now on public.
Users browsing this forum: No registered users and 62 guests
