It is currently Tue May 26, 2026 3:38 am
 Post subject: Weber Icing
PostPosted: Fri Jan 05, 2007 12:31 pm
With a minimum of fabrication, you can use the Luv breather and hook up the gooseneck to the exhaust manifold heat shield to eliminate the icing. There's about a 1/2 to 1 inch clearance for it under the hood when done.
