It is currently Tue May 26, 2026 7:41 am
 Post subject: 1.8L Stroker
PostPosted: Tue Jan 02, 2007 11:12 pm
How and is it possible
if u know...
explain it to me if u could be so kind
On the search for another Luv Machine
PostPosted: Wed Jan 03, 2007 1:04 am
not going to be able to stroke the g180. im dont even think you could offset the crank either sine there are no smaller journal isuzu motors.
PostPosted: Wed Jan 03, 2007 11:05 am
Anything is possible with enough money, but stroking a 1.8L would take quite a bit of it. There are no off the shelf parts to do it, so think custom forged everything. The end result might be problematic too, as the poor little 1.8L needs to rev pretty high to make its power in stock form. You could get a little bit more power lower down and sacrifice high RPM durability. You are better off to just upgrade the motor with something else unless you just really want to be different. (or bore out a a G200 and build a high compression 1.9-2.0L motor)
PostPosted: Wed Jan 03, 2007 1:01 pm
ya it was just an idea
but that would be pretty cool
Users browsing this forum: Bing [Bot] and 79 guests
