It is currently Tue May 26, 2026 5:59 am
 Post subject: Heater
PostPosted: Sat Dec 09, 2006 2:15 am
my heater is working somewhat, but not like it use too, any ideas as to what happen?
PostPosted: Sat Dec 09, 2006 1:55 pm
Perhaps The Blower Motor Is Going Out? I'm Not Really Sure Without Seeing WhatExactly It Is Doing.
 Post subject: heater
PostPosted: Sat Dec 09, 2006 3:24 pm
There's a valve on the firewall run by the temperature lever on the heater console. Make sure that's working.
PostPosted: Sat Dec 09, 2006 3:29 pm
Thats Probably It. Hes Already Started Asking About Where To Get One and The Hose That Goes To It Aswell.
PostPosted: Sat Dec 09, 2006 9:05 pm
Your heater core might be clogged up or restricted. We just swapped one out on my son's 80 LUV. No biggie.
Check by disconnecting the hoses to the core. Attach a hose and blow through the core. It should be easy. If not ... there you go!
A good flush might help, if you make sure that a lot of clean water goes through the heater core.
A replacement for the 80 was about $45.
PostPosted: Sat Dec 09, 2006 9:09 pm
Good Tip That Wouldn't Hurt To Do Even If It May Not Be The Cause.
Users browsing this forum: No registered users and 56 guests
