It is currently Wed May 27, 2026 4:13 pm
 Post subject: fuel pump?
PostPosted: Mon Mar 10, 2003 10:55 pm
i have a 1980 4x4 luv deisel, well filter light was on so changd filter now wont start, was it fuel pump allalong or i messed up? thanks in advance
PostPosted: Mon Mar 10, 2003 11:15 pm
A standard practice with diesel motors is that after changing a fuel filter, you must bleed the air out of the system. Im not familiar with Luv diesels in particular but there must be a shrader valve looking thing on or around the filter housing that you must depress while turning the engine over. This will bleed the air from the system and then it should start.
 Post subject: thanks
PostPosted: Mon Mar 10, 2003 11:45 pm
i will try and see as i am unfamiliar also . any info would be helpfull
