It is currently Sat Jun 13, 2026 1:42 am
PostPosted: Mon Oct 28, 2002 11:44 pm
does anybody know if a 5 speed out of an 83 to 89 camaro will fit into a chevy luv behind a small block as this is a wire linkage and i really dont want to switch over to a hydraulic clutch any help would be greatly appreciated and i f*in love your guy's site
PostPosted: Wed Oct 30, 2002 12:37 am
hmmm...I thought the LUV's w/ manuals came with a hydraulic clutch. Is the linkage factory? As for the trans, you can make anything fit.
PostPosted: Wed Oct 30, 2002 1:30 am
All 3 of the ones i had.. (2) 1980 - 4x4, 4 Spd, and a 1979 4x4, 4 Spd both had Cable clutches.. Straight cable form the pedal to the arm in the transmission.. I dont know about the others.. or the 2wd...
PostPosted: Wed Oct 30, 2002 1:33 am
The 76 2wd I owned had a manual clutch. It's amazing how far you can adjust those things when you're too lazy to replace a pressure plate. *crunch* is the key word. :roll:
PostPosted: Wed Oct 30, 2002 10:39 pm
ive read in other posts that i had to use a monza bellhousing, shifter fork and throwout bearing is this true with a 5 speed out of a camaro or can i just use all of the stock bellhousing and equipment this help will be greatly appreciated since as far as i know im about to have to go hard to find parts shopping but i really hope not thanks for the help guys :x
PostPosted: Wed Oct 30, 2002 11:41 pm
The earlier trucks had hydraulic clutches. I believe they went to the cable in 76.
Sorry, I can't help with the main topic. :(
PostPosted: Sun Nov 03, 2002 12:58 pm
Does anybody know if a 4-speed shifter will bolt up to the original hole?
 Post subject: REPLY TO QUOTE
PostPosted: Fri Feb 07, 2003 9:22 pm
Anonymous wrote:
Does anybody know if a 4-speed shifter will bolt up to the or :oops: iginal hole?
Quote:
I HAVE 72 LUV , UNFORTNALY IT DOESNT FIT. U HAVE TO CUT THE FLOOR ABOUT 6'' TO 8'' BACK FROM STOCK HOLE OR SO.
PostPosted: Fri Feb 07, 2003 10:40 pm
The clutches went to cable in 78. 72 to 77 were hydraulic.
PostPosted: Tue Feb 25, 2003 12:05 am
the camaro 5 speed works great use a v8 monza bell houzing and use the cable clutch super simple i have that set up in my v6 truck have fun mike 8cyl
PostPosted: Mon Mar 10, 2003 5:14 pm
i dont know about you guys but when i get my 327 in a luv it will have a 'vet 6speed behind it :twisted: I have a buddy whith one that i might be getting soon. Talk about speed deamon! 8O
PostPosted: Mon Mar 10, 2003 7:51 pm
I wanna get a richmond six speed and put some seriously tall gears in the rear....
Ah... wishful thinking.... :wink:
PostPosted: Mon Mar 10, 2003 8:05 pm
I have a 1978 stepside and it had an hydraulic clutch.
PostPosted: Mon Mar 10, 2003 9:11 pm
maybe the hydro clutch was an option? :?
PostPosted: Mon Mar 10, 2003 9:23 pm
my 80 was a dry clutch....i think this has been discussed b4...and i believe it was decided that they went to cable in 79
