It is currently Mon Jun 08, 2026 3:42 pm
 Post subject: oil type
PostPosted: Fri Sep 08, 2006 6:44 pm
what is a good oil to run in a 1.8
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
PostPosted: Fri Sep 08, 2006 7:37 pm
10w30 is an all around good oil.
PostPosted: Sat Sep 09, 2006 4:30 pm
cool thanks man i just wasnt sure if i should run a thick oil weight or not thx alot
bracket racer
PostPosted: Sat Sep 09, 2006 5:40 pm
I've run Chevron Delo400 15-40 in mine quite a bit, but I don't think there is really a need for it. 10-30 is good for most climates. If you find that it smokes, go up a grade next oil change and see what it does for you. My 79 really liked to have 15-40 or it would smoke on startup, but my 77 (with more and harder miles on the motor) doesn't smoke or use much on 10-30.
If you want to spend a bunch of money on oil, Mobil1 10-30 fully synthetic is some good stuff. You have to watch putting synthetic in an older motor though as it can sometimes cause old seals to start leaking. It cleans the gunk out of the motor a little better, and in the process can open up old brittle seals.
PostPosted: Sat Sep 09, 2006 5:50 pm
i run 10w40 since i do ALOT of highway driving. 10w30 will thin out quite alot after running 3500rpm for 3hours 8O
PostPosted: Sat Sep 09, 2006 6:02 pm
Clean oil is the best kind of oil to run in any engine. Keep the level up and change it when it gets dirty.
