It is currently Mon Jun 08, 2026 7:18 am
PostPosted: Mon Sep 04, 2006 1:01 pm
sleeps at LUVTruck.com
Does anybody know where I can get a Windshield washer pump for a 79' 4x4 luv? I don't want a universal i want one that is made for a luv
PostPosted: Mon Sep 04, 2006 2:00 pm
Do you need just the electric motor? I have a couple but they don't work. Try taking it apart and cleaning it out. That's what I had to do. I think one of mine just fell apart, the screws were all rusted out. But another one I had came apart and went back together ok. I take it apart and then hook it to some 12 volt , manually turn it and see if you can get it going.
PostPosted: Tue Sep 05, 2006 7:16 pm
Thanks, I'll try that first. :!:
PostPosted: Tue Sep 05, 2006 7:25 pm
I hade to use 2 pumps to make one good one.
PostPosted: Wed Sep 06, 2006 4:20 am
PITA Old Fart
Yeah...most of the time if you take the motor apart and clean out the built-up rust and soap gunk out of it...it'll run fine once you put it all back together.
Out of all of the Luv's I've ever owned...only 1 had a working washer....all of the rest I had to tinker with.
PostPosted: Wed Sep 06, 2006 5:01 am
i've never had a washer problem with mine. infact i turned my passenger side sprayer towards the sidewalk so i can spray pedestrians.. i get about 20 ft range :lol:
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Wed Sep 06, 2006 7:02 am
:twisted: He He i like that :twisted:
PostPosted: Wed Sep 06, 2006 3:23 pm
It has just recently gone out. Before we've never had any problems with it. :?
PostPosted: Thu Sep 07, 2006 3:51 pm
I tried to clean it out but everything moves smoothly so I don't know what is going on. :(
PostPosted: Thu Sep 07, 2006 4:20 pm
Well maybe the motor is burnt out. It was at least worth a try. Maybe someone on here has one for you.
PostPosted: Thu Sep 07, 2006 4:44 pm
could be a fuse or the switch. those switches are pretty cheaply made... try putting power right to the motor. good luck :D :wink:
PostPosted: Fri Sep 08, 2006 12:47 pm
There's one one ebay right now but the auction ends in two hours from now...
Item number: 330024268296
79 Black Mikado longbed with AT & AC...
PostPosted: Fri Sep 08, 2006 6:26 pm
I think the motor is burn't out.......oh well it was worth a try. :smt009
PostPosted: Mon Sep 25, 2006 6:42 pm
Hey guys I finally got the windshield motor working :wink:
PostPosted: Mon Sep 25, 2006 11:13 pm
How did you fix it?
PostPosted: Tue Sep 26, 2006 3:15 pm
Just a little more cleaning. I was determined to get it fixed. 8)
PostPosted: Tue Sep 26, 2006 3:38 pm
Cool!
PostPosted: Tue Sep 26, 2006 4:39 pm
Just fixed mine it would not work went into it and cleaned it. Were the magnets come into contact it was gummed up so a little sanding and it works fine. It still wouldn't spray till I made new holes in the metal nozzle.
PostPosted: Tue Sep 26, 2006 4:44 pm
Heh.
I suppose I should try mine before it rains...
PostPosted: Tue Oct 03, 2006 9:47 pm
Get one from JCWhitney for $12, then mount it inside the box next to the reservoir. Nobody will know the difference, and you'll have a clean windshield!!!!
