It is currently Mon Jun 08, 2026 4:25 pm
 Post subject: Secondaries not working
PostPosted: Fri Sep 29, 2006 6:04 pm
Can anyone tell me how to check, fix and or repair the diaphram on the hitachi carb. that opens up the secondaries.
Thanks
 Post subject: secondary
PostPosted: Sat Sep 30, 2006 11:20 pm
Remove the short hose from the actuator, put a length of tubing over the connector stub and suck on the other end. If you draw air easily, the diaphragm is leaking. I don't know how you could repair a leak and still get the secondary throttle to kick in accurately. The arm that moves them is attached.
