It is currently Mon Jun 08, 2026 2:32 pm
 Post subject: NO LIGHTS
PostPosted: Wed Aug 23, 2006 12:13 am
ok here is a good one for you guys. i was driving my 79 luv with a 76 grill in it so there are 4 head lights. anyway just goin down the road and all lights went out. the ONLY lights i have are two on the dash that are red.
all green dash lights dont work. NOTHING. ive checked most of my wires and i know that my switch is working and i have pwr to lights y dont they come on. you would think that they are blown but every light is blown at once~!!! thats a little od i think?
PostPosted: Wed Aug 23, 2006 12:25 am
Check your fuses and fuse block. That's the weakest part of a LUV electrical system. It's possible to have a major short in the wiring somewhere but i have to think to start at the fuse block.
PostPosted: Wed Aug 23, 2006 10:30 am
There is one fuse in the block for the "lighting switch" that could blow and take out all of the lights. Check that out and see what you find. Also, when you look at the fuses, don't assume they are good if they look ok. I've had several where the fuse broke inside near one end and they looked just fine.
PostPosted: Thu Sep 07, 2006 12:23 am
Check the voltage output from the regulator; it may be buggered and putting out way too much voltage. This happened to me and I kept losing the lights because it was blowing fuses. Also the turn signal/hi beam switch may be worn and will sometimes blow fuses if signaling with the hi beams on. this is on a 77 so it may be different on you 79. Good luck! Crap, but I hate automotive electrical systems!
