It is currently Mon Jun 08, 2026 11:18 am
PostPosted: Wed Jul 19, 2006 1:52 pm
Uncovered Weber, air injection rail removed, pressure regulator in background, starting to take shape.
PostPosted: Wed Jul 19, 2006 6:58 pm
Man, it looks so much better without all the smog equipment in there! Where did you get that cap for the valve cover? Did you put a new intake on it or do you have the adapter plates? Good luck, RF
PostPosted: Wed Jul 19, 2006 8:21 pm
Thanks. Yeah, and it's gotta be at least 10lbs of crap I took off.
If you are talking about the rubber cap at the rear, got it at Pep Boys. It was on their grommet rack. Maybe $2.00?
It's the original intake with an adaptor plate for the Weber, and a blank where the EGR valve use to be. I have another Luv manifold without the port for the EGR, it's going on later.
Thanks to all the various contributors whose advice helped me get this far!
Users browsing this forum: Bing [Bot] and 28 guests
