It is currently Mon Jun 08, 2026 12:10 pm
PostPosted: Wed Jul 19, 2006 1:52 pm
Uncovered Weber, air injection rail removed, pressure regulator in background, starting to take shape.
PostPosted: Wed Jul 19, 2006 6:58 pm
Man, it looks so much better without all the smog equipment in there! Where did you get that cap for the valve cover? Did you put a new intake on it or do you have the adapter plates? Good luck, RF
PostPosted: Wed Jul 19, 2006 8:21 pm
Thanks. Yeah, and it's gotta be at least 10lbs of crap I took off.
If you are talking about the rubber cap at the rear, got it at Pep Boys. It was on their grommet rack. Maybe $2.00?
It's the original intake with an adaptor plate for the Weber, and a blank where the EGR valve use to be. I have another Luv manifold without the port for the EGR, it's going on later.
Thanks to all the various contributors whose advice helped me get this far!
