It is currently Tue Jun 09, 2026 1:31 pm
PostPosted: Sat Jul 22, 2006 8:45 am
I got a dizzy out of an 84 and dropped it in my 79. Probably the quickest thing I've done so far. The 84 was a 1.9, mine is a 1.8.
Will the head swap straight across? Have an opportunity to pick up the head from the same guy. The thought is to get this head worked, and put it on the shelf till I'm ready to do the block.
Thoughts?
PostPosted: Sat Jul 22, 2006 10:23 am
That will drop your compression. What most people do is put the G180 head on the G200 engine to boost compression.
-DK
PostPosted: Sat Jul 22, 2006 11:48 am
Thought was to punch the 1.8 out to 2.0, then use the 1.9 head for a slight compression increase. I should have been more clear. Sorry.
