It is currently Mon Jun 08, 2026 8:32 am
 Post subject: stuck crankshaft bolt
PostPosted: Sat Jun 24, 2006 2:05 pm
Hey all,
I have a 79 LUV with a stock engine and my timing chain broke and I am in the midst of replacing it (and the gears/sprockets and tensioner). I am trying to do this with the engine still in the truck. I took out the radiator and have a lot more room to get the front cover of the engine off. I just can't get the crankshaft bolt off. When I turn the socket wrench (with two foot cheater bar), the whole pulley/gear aparatus turns (though it gets harder to turn as I turn it). I have the truck blocked and the emergency brake on and have tried having the truck in reverse and in second gear, but I just can't get the durn thing to break loose. Any ideas? I have an impact socket driver but there is not enough clearance to swing the hammer very far.
Thanks!
PS can I get the front cover off without removing the head (I just changed the head gasket a month ago!)
PostPosted: Sat Jun 24, 2006 2:59 pm
The trick I've used is to put the socket on a breaker bar, turn the motor over by hand so that the bar is wedged against the frame, then just bump the starter a bit. I've yet to have one stay stuck after that. Just make sure you get that socket on tight (using a 6 point socket helps too) and the bar against something solid. A block of wood in there would help protect things.
PostPosted: Sat Jun 24, 2006 6:01 pm
Hey 800XL!
Thanks dude! That totally worked! I had been fighting that bolt for like 3 hours! whew! time for a beer.
PostPosted: Sun Jun 25, 2006 12:11 am
That is a good trick. We used it all of the time at the dealer.
PostPosted: Sun Jun 25, 2006 2:25 pm
The 2.3L motor I just put in my Trooper did resist a little bit, until I hooked up an Optima red top battery.
