It is currently Sun Jun 07, 2026 6:11 pm
 Post subject: 82 ignition in an 80
PostPosted: Sun Jan 26, 2003 5:35 pm
Well i got the 82 electronic ignition put into my 80 luv. If anyone is interested in doing this pm me and ill tell you what you need to do. As far as performance bennies, the motor has never idled so smooth and it will rev up to 6000rpm (floats the valves then 8O ). And it only took me about a half hour to do it too.
PostPosted: Sun Jan 26, 2003 11:51 pm
Alrighty if you dont get a replay form a pm to me in short order dont worry after having two people ask me for the directions in about 6hours im going to type up a repaort and see if i can get pics into it too.
PostPosted: Mon Jan 27, 2003 12:39 am
If you could make it into a formal article, I would gladly post it in the information section.
PostPosted: Mon Jan 27, 2003 12:58 am
I have something typed up fairly formally, i was going to see if i couldnt track down the part numbers for the stuff i used and throw them in there too.
 Post subject: electronic ignition
PostPosted: Mon Mar 03, 2003 12:45 am
I have been wanting to put electronic ignition in my '74. Do you think the '82 swap would work?
PostPosted: Mon Mar 03, 2003 6:02 pm
well i dont know exactly if it will. I have heard that the only diferance between the 70s motors and the 80s motors is everything (starter intake exaust ect.) ar on opposite sides, if this is the only diferenc then it should work for them too. But as far as right now all i know for that will work is 78-80 (ore the one whith the starter and intake on the passenger side).
PostPosted: Mon Mar 03, 2003 6:03 pm
wait what sireis is your luv. I have shop manuals for em all and i could see what the actuall diferences are.
PostPosted: Tue Mar 04, 2003 2:18 am
Mine is a '74 so I think that's a series 3 correct me if I'm wrong.
Users browsing this forum: Google [Bot] and 35 guests
