It is currently Mon Jun 08, 2026 12:02 pm
PostPosted: Mon Apr 17, 2006 2:41 am
I recently installed a weber on my new 79 4x4 and I had a few questions. First of all are you guys still using the fuel return? How about that vacuum port facing passenger side on the carb. Where does that go? Also it doesnt look like my electric choke is opening up with time. Another problem I have is the truck wont start without a shot of engine starter and once I do it starts right up :( Help! :(
PostPosted: Tue Apr 18, 2006 4:31 pm
As for the return line on mine I did have it hooked up. I had two nipples off of the carb so I used one for the return. the choke, you should have two wires that went to the original carb, one for the choke and one for the anti-dieseling solenoid, make sure you have the right wire to the right connector. Other than that maybe you need to adjust the choke itself, by loosening the screw(s)? and turning it a little CCW ( I think). The vac line, if no one responds in the meantime, I will see if I can find what I had them plumbed to or capped off...
as far as starting...?
Resident lurker
PostPosted: Tue Apr 18, 2006 7:06 pm
I just plugged my return line off. The vacuum port on the passagener side is a timed vacuum. You have to tee off it an run one line to the egr valve. The other one goes to the vacuum port on the distrburtor.
PostPosted: Thu Apr 20, 2006 1:24 am
PITA Old Fart
Be careful with the starting fluid...frequent use is not too good for your engine.
That stuff burns a lot hotter in your cylinders than regular gas.
PostPosted: Fri Apr 21, 2006 2:07 am
hmm thanks for that. Also why does this thing smell like a lawn mower? the exhaust.
PostPosted: Fri Apr 21, 2006 2:10 pm
If it smells funky then the mixture is probably off. Take a look at http://www.carburetion.com/Weber/adjust.htm and go through the adjustment procedure. It is really easy to do and should get you running better.
Somewhere I saw a how-to for choke adjustment, but I could not find it. It does sound like you need to adjust it, that should cure the hard starting. Basically, a lean choke will cause spitting sputtering on acceleration when the engine is cold. Too rich of a choke will cause a lopey stumbling idle when cold. If I recall correctly turning the choke housing CCW is leaner, clockwise is richer. To get a starting point, adjust it so the choke butterfly is closed when cold, but doesn't slam shut hard when you cycle it with your finger. It should just close.
PostPosted: Tue May 02, 2006 2:50 am
Okay, I ran the vac line from the carb to the dist but didnt t off to the egr (I dont know where it is) and still doesnt start without starting fluid. I did folow the tuning link for the webber but no dice. I started up with the fluid and died shortly there after and wouldnt start again without fluid. Sounds like a fueling issue but I dunno. Suggestions? How important is it to have the EGR hooked up?
PostPosted: Tue May 02, 2006 8:16 am
check the float
PostPosted: Tue May 02, 2006 2:16 pm
The EGR only makes a difference under load at higher RPMs. It dumps some exhaust gas into the intake to cool down cylinder temps, which reduces pinging and NO2 emissions. It is located on the bottom side of the intake, and the line should go from it to a thermal switching deal screwed into the intake manifold up higher, then out of that to the vac source. It should also not be hooked in with the distributor. The EGR should get manifold vacuum and the distributor should be hooked to a ported vac source on the carb. Until you get things running right, I'd just leave it unhooked.
The starting issue to me sounds more like the choke than anything else. Does it make any difference in starting if the motor is fully warmed up? My best guess is that the choke isn't closing enough when its cold, so it should start pretty well when its already warmed up.
PostPosted: Tue May 02, 2006 3:27 pm
According to my series 8 book for a 1978 chevy luv. The EGR valve vacuum diaphragm chamber is connected to a timed signal port in the carburetor flange through a thermal vacuum valve.
PostPosted: Tue May 02, 2006 3:36 pm
The EGR valve has a timed port control and a temp control for it . The EGR valve won"t open until the rmps are high enough and the engine is at normal temp.
PostPosted: Tue May 02, 2006 3:37 pm
If it was open at idle it would run rough.
