PostPosted: Fri Apr 21, 2006 4:12 pm
well i dropped the oil out of my tranny today and found some little guys hanging out on the drain plug. I pulled out 3 pieces of metal, none of them any bigger than an unpoped peice of popcorn. But still im just wondering where they came from and how long untill something goes boom...
Guess i better pull the 79s tranny and have it ready... :lol:
PostPosted: Fri Apr 21, 2006 8:08 pm
Hey Mepr,
How do you like your 48 Pontiac with the flathead? My dad is building a 29 Model A with a 52 Ford Flathead. 8)
PostPosted: Sat Apr 22, 2006 7:07 am
have fun changin out that tranny. i had a whole gaggle of fun when i did it in the pup, and its only a 2wd 8O
PostPosted: Sat Apr 22, 2006 5:03 pm
Yep, have fun, on the diesels you have to almost put them in position, turn it sideways, wiggle it up, turn it right-side-up, then TRY to put the input shaft in the pilot bearing.... which is hard, we had to taper the shaft so i'd slide in better, even then we had to put in a couple of bolts to tighten it up and draw it in, we had to try to put it in three times before we got it in.
PostPosted: Sat Apr 22, 2006 6:50 pm
i have had this engine and tranny out so many times. Its maybe an hour job start to finish...
PostPosted: Sat Apr 22, 2006 7:56 pm
Sounds like your an know quite a bit on Flatheads. My dad has his motor in a Shop in sacamento that specalies in older motors.
Between 2 loves, I've pulled the transmission out quite a few times that i got it down pretty quickly. Escpecially now that I have a removable crossmember for the 5 speed.
PostPosted: Sat Apr 22, 2006 9:19 pm
Zane, i was talking about the LUV in my last comment.
As far as the Pontiac goes, i dont have it home yet. Its stranded in Wenachee at my uncles place. Watch the lounge for the story on that one :lol:
