It is currently Mon Jun 08, 2026 7:18 am
 Post subject: steering
PostPosted: Fri Mar 31, 2006 2:08 pm
With you laying under the front end to watch the tie rods, pitman arm and idler arm have someone twitch the steering wheel back and forth within the play limits, watch to see if any play is showing in the above parts. If not, then adjust the steering gear box with the adjusting screw on top. Don't jam it tight or you'll were the box out prematurely.
